| The following warnings occurred: | |||||||||||||||
Warning [2] Undefined variable $unreadreports - Line: 31 - File: global.php(961) : eval()'d code PHP 8.3.32 (Linux)
Tuning box Hdi - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Tuning box Hdi (/showthread.php?tid=25419) |
Tuning box Hdi - RJBillWCA - 21-07-2014 Advice and opinions on a tuning box for an X reg 306 HDi? Re: Tuning box Hdi - kentiiboii - 22-07-2014 Get a remap. Cheaper, better, more economical and more power. it's just better all rounder. RE: Tuning box Hdi - Poodle - 22-07-2014 Know of a few who have killed their fuel system with a tuning ox, just do it properly and get a remap. RE: Tuning box Hdi - Pete - 22-07-2014 Got one on the van due to its ghey Siemens ecu. Tested it on a rolling road had small gains (10 bhp and about 30 torquey things) get afew more mpgs aswell but on the 306 a proper remap is a no brainer really. RE: Tuning box Hdi - jammapic - 22-07-2014 Yep, wouldn't bother with a tuning box. A remap gives all of the above as the guys have pointed out, but I'd actually argue it's easier to remove than a tuning box too... you don't even have to lift the bonnet!! JP RE: Tuning box Hdi - bashbarnard - 22-07-2014 Its all about remaps. There is no substitute for them. 9 times out of ten all tuning boxes do is put resistors between certain inputs to ecu like temperature or boost. Its not accurate at all and defintly not good for the motor. RE: Tuning box Hdi - jammapic - 22-07-2014 (22-07-2014, 08:31 AM)bashbarnard Wrote: Its all about remaps. There is no substitute for them. 9 times out of ten all tuning boxes do is put resistors between certain inputs to ecu like temperature or boost. Its not accurate at all and defintly not good for the motor. Yep, all they do is intercept signals to fool the ECU. To a point, they work... but there's no substitute for actually telling the ECU WHAT to do. JP RE: Tuning box Hdi - dashmader - 27-07-2014 (22-07-2014, 11:45 AM)jammapic Wrote:(22-07-2014, 08:31 AM)bashbarnard Wrote: Its all about remaps. There is no substitute for them. 9 times out of ten all tuning boxes do is put resistors between certain inputs to ecu like temperature or boost. Its not accurate at all and defintly not good for the motor. Indeed, all the boxes i saw are resistors, and most of the time are bad resistors and overall construction |
