Oil cooler or radiator? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Oil cooler or radiator? (/showthread.php?tid=25073) |
Oil cooler or radiator? - aggyj17 - 06-07-2014 Just a quick question for my 205 it seems to get hot when on full boost not overly fast but I can't drive hard for any decent length of time though. I am running a 1.9 gti radiator which is around 15mm thinner than a dturbo one Also I am not running ANY oil cooler not even the standard one What would you guys recommend getting first a decent rad or an oil cooler? RE: Oil cooler or radiator? - cully - 06-07-2014 both if you drive the car hard regularly RE: Oil cooler or radiator? - Tom - 06-07-2014 Welcome to xud tuning... You can buy uprated ones for the 205 on ebay, close to 200quid though, go through the adverts and buy the thickest one you can, thats what i would do anyway. Then buy an oil cooler aswell, if your running big psi that turbo is really shagging your oil... Edit, also its a really bad idea not to use the standard heat exchanger. RE: Oil cooler or radiator? - Uberderv - 06-07-2014 I would get the oil heat exchanger on first, then if needs be get a td rad as they have the largest capacity. Is your water pump fairly new? RE: Oil cooler or radiator? - aggyj17 - 06-07-2014 I was thinking about getting an aftermarket thermostatic controlled oil cooler RE: Oil cooler or radiator? - welshpug - 06-07-2014 Get a turbo rad RE: Oil cooler or radiator? - rryan - 06-07-2014 the 205 dt radiator did the job for me very well, when i had my 205. i also used the standard xud9 oil to water heat exchanger. i dont know what the oil temps were, but the coolant temp acted the same as if the engine was in a 306 RE: Oil cooler or radiator? - Dave - 07-07-2014 Jesus, no oil cooler at all is bad, especially if you don't know you're oil temps they could just rise and rise even with standard driving because you have NO cooling what so ever, then you'de have no oil pressure either. Defo go for the oil cooler first, otherwise with an uprated rad you'de be tempted to drive it hard because your water temps are low, but oil could be literally boiling. RE: Oil cooler or radiator? - aggyj17 - 07-07-2014 Cheers for the reply guys. I bought a mocal oil cooler last night so will get that on ASAP lol RE: Oil cooler or radiator? - aggyj17 - 07-07-2014 I will need to run a smaller oil filter what filter do you guys run?? Oil cooler or radiator? - td_dan - 07-07-2014 Renault kangoo oil filter supposedly fits RE: Oil cooler or radiator? - toseland - 07-07-2014 i dont have this issue..... i have about 7 inches between the oil filter and the passanger side mudgard haha. RE: Oil cooler or radiator? - Uberderv - 08-07-2014 I think the 2.1 xud filter is shorter, can measure it for you like? RE: Oil cooler or radiator? - aggyj17 - 08-07-2014 Yea if you could please mate cooler turned up today so hopefully put it on friday RE: Oil cooler or radiator? - Tom - 08-07-2014 Theres one from a 97 ish renault megane 1.9 that fits! Its noted in my old 205 project thread somewhere! RE: Oil cooler or radiator? - mr_fish - 09-07-2014 (08-07-2014, 07:13 PM)Tom Wrote: Theres one from a 97 ish renault megane 1.9 that fits! Its noted in my old 205 project thread somewhere! What Tom said. I'm using that filter on mine. RE: Oil cooler or radiator? - Uberderv - 09-07-2014 This be the filter I use - www.opieoils.co.uk/p-69224-mahle-oil-filter-oc976-citroen-peugeot-.aspx It's about 3 inches long |
