| The following warnings occurred: | |||||||||||||||
Warning [2] Undefined variable $unreadreports - Line: 31 - File: global.php(961) : eval()'d code PHP 8.3.32 (Linux)
boot squeaks!! and squawks!!! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: boot squeaks!! and squawks!!! (/showthread.php?tid=24814) |
boot squeaks!! and squawks!!! - Piggy - 24-06-2014 I have managed to narrow down all manner of rattles etc to the point where I feel I am down to one major squeak/squawk... That of the boot. It squeaks and squawks so much! I cant find anything lose or that moves how it shouldnt... Any ideas?? RE: boot squeaks!! and squawks!!! - WiNgNuTz - 24-06-2014 Sounds like you've got some kind of bird in the boot?
RE: boot squeaks!! and squawks!!! - DeeTurbo - 24-06-2014 Check your catch, the part that is on the body. If you turn the plastic round bit you will see the bit that catches on to the latch has worn through the plastic. By turning the plastic it will stop the metal of the latch wearing on the metal that is exposed on the catch. I'll take some photos if that doesn't make sense. RE: boot squeaks!! and squawks!!! - Piggy - 24-06-2014 Nice one DT... Danny said similar actually! boot squeaks!! and squawks!!! - Kwik - 24-06-2014 Should be two rubber stops on each side Of boot lid They can screw in and out adjust them out and that will stop squeaks RE: boot squeaks!! and squawks!!! - Piggy - 25-06-2014 Tried them kwik boot squeaks!! and squawks!!! - Kwik - 25-06-2014 Other one is tap the plastic trim on tailgate under window inside and see if that is knocking inside? I took my old one off and padded it out and had to do same with the estate RE: boot squeaks!! and squawks!!! - Eeyore - 25-06-2014 The top rear brake light will sometimes rattle and need padding out. My car makes loads of rattling noises. Best way to solve this would be to strip it
boot squeaks!! and squawks!!! - Kwik - 25-06-2014 (25-06-2014, 08:34 AM)SRowell Wrote: The top rear brake light will sometimes rattle and need padding out. My car makes loads of rattling noises. Best way to solve this would be to strip it Yes I did my brake light too thinking about it RE: boot squeaks!! and squawks!!! - Piggy - 25-06-2014 Brake light is sorted...did that first!! Haha boot squeaks!! and squawks!!! - Kwik - 25-06-2014 Lol cool another thing to check is all trim is on properly RE: boot squeaks!! and squawks!!! - Piggy - 25-06-2014 Danny was first in...and I love him!! It was the little plastic shrowd on the boot catch...spun it round, it had worn to the metal...and drove home... NO SQUEAKS or rattles!! So other than f/n/s suspension creak....it was so quiet!!! Very pleased thanks all ![]() Now just to sort the tyre/road noise!! RE: boot squeaks!! and squawks!!! - Danny2009 - 25-06-2014 Glad it's sorted mate
RE: boot squeaks!! and squawks!!! - Piggy - 26-06-2014 For anyone wondering what the exact issue is.... [attachment=17165] RE: boot squeaks!! and squawks!!! - j77hrn - 02-08-2014 Never even thought of checking that, cheers ? RE: boot squeaks!! and squawks!!! - Eeyore - 02-08-2014 Oh wow. May have to check that. RE: boot squeaks!! and squawks!!! - Slam Wagon - 02-08-2014 What are people using to pad out the trim with? Also anybody got a more perminent solution than twisting the plastic? I find it just spins back. RE: boot squeaks!! and squawks!!! - cully - 02-08-2014 spiral cut some nylon air tube
