7TE is a 1.7 right ? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: 7TE is a 1.7 right ? (/showthread.php?tid=24579) |
7TE is a 1.7 right ? - andyyy - 12-06-2014 Right so the engine in my 205 siezed solid and had no compression so took it out yesterday And I was sold the car being told it was a 1.7 NA car with a 306 1.9TD engine put in it ( the one I took out cause it seized up ) But on the back of the engine it says 7TE which leads me to believe its the 1.7 na engine but some ones bolted up a turbo too it ? Anyone clear all this up for me ? RE: 7TE is a 1.7 right ? - Mattcheese31 - 12-06-2014 i believe they did turbo 1.7 units (i could be wrong) they certainly did turboed 1.8 ones . . ![]() RE: 7TE is a 1.7 right ? - aggyj17 - 12-06-2014 The 1.8 205 engines are xud7te so most likely has had a 1.8 turbo lump put in it RE: 7TE is a 1.7 right ? - andyyy - 12-06-2014 ahh okay is there much in one vs a 1.9? RE: 7TE is a 1.7 right ? - Ruan - 12-06-2014 XUD7 is a 1769cc - which rounds to 1.8. XUD7A was put in 205 NAs. XUD7TE was put in 205 DTurbos. XUD9TE was put in 306 DTurbos. Looks to me like it's had a XUD7TE (turbo) out of a 205 put in. RE: 7TE is a 1.7 right ? - andyyy - 12-06-2014 I best have a word with the matey who sold me the car then as he seemed convinced it was a 1.9TD out a 306 RE: 7TE is a 1.7 right ? - Ruan - 12-06-2014 He'd be wrong then!!! Take a photo of the manifolds on the back as you've got it out... That's the giveaway if it genuinely is an XUD7TE. I'd expect it is an XUD7TE since it's much easier to fit... Does it have the pulleys on the side of the cylinder head or does it ha?ve just a single vacuum pump...? RE: 7TE is a 1.7 right ? - andyyy - 12-06-2014 (12-06-2014, 03:04 PM)Ruan Wrote: He'd be wrong then!!! Just single vac pump and it says 7TE on the block from where its cast Im not pissed off or anything just curious to how he got confused as i bought it as a non runner that had been sat up for years anyway. |
