GI/WIW: - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: For Sale (https://www.306oc.co.uk/forum/forumdisplay.php?fid=26) +--- Forum: Cars (https://www.306oc.co.uk/forum/forumdisplay.php?fid=21) +--- Thread: GI/WIW: (/showthread.php?tid=24552) |
GI/WIW: - Lolben91 - 10-06-2014 My 1999 3 door 306 Dturbo in Dragoon blue ( KNP ) DHY block (has DHY in chassis number), Lucas pump, K14 turbo on non EGR manis, hasnt been tuned Clock shows 112352 Has MOT till April 6th 2015, no tax as is SORN Located in the Birmingham B37 area The car has only let me down once when the turbo blew on the M42, dont believe there is any damage to the engine as it only ran away for a few moments while travelling at 70 mph before stopping on the hard shoulder leaving it in 5th gear which stalled the engine, replaced the blown T2 with a K14 and it runs as good as it ever did, better even as i find the K14 spools faster and made the drive much more fun. The turbo blew at around 110050 odd miles, the next day took me to and from Dorchester without a problem Has been serviced every 5000 miles in my owner ship Bought the car with around 91k on the clock, was told when i bought it that the headgasket, belt, waterpump etc had been done about 10k ago, though i have no proof i do not believe the guy was fibbing as the head was spotless If you search "crap in oil" in the XUD section, the engine does this, im told its the head gasket going, but im also told its condensation. It got worse when i removed the turbo intake pipes after the first turbo blew, but at that time found the rubber that connects the intake pipe to the turbo had split almost completely in two pieces, so i believe it is condensation as there wouldnt have been sufficient air flow in the oil filler neck to keep heat soak from building It does drink/leak water, cant find where from and needs topping up every 150 miles or so Leaks oil from the pulley crank seals, not massively but enough to piss my dad off The remote central locking works, but something is wrong with the key fob as it will drain new batteries in about 2 days, can lock/unlock the doors from the door locks Rear lights are half tinted (indicator part) but i can supply some standard replacements GOODIES: S16 half leathers, very little wear but drivers frame has had welding Full exhaust, de-cat, hoffmann midpipe, universal backbox, box has a split at the back from being low but it doesnt blow Team Heko wind deflectors Tinted windows (rear not done) drivers needs redoing as has been scratched and has a hole in the tint (am supplying a replacement untinted drivers side window) Blue carpet, not mint and doesnt fit perfectly but its in there GTI boot trim Nissens radiator BADS: Swallows. All tyres are above the legal limit, drivers one ideally needs replacing as its got quite a bit of cracking. Also the centre caps have lost their paint Dings/little dents down both sides Quite a few stone chips to the bonnet Front bumper has 2 large scuffs and 1 row of scratches Rear bumper has scratches at the bottom Boot has a dot of paint loss that has rusted, boot badge is pealing is lacquer, also has a dent and scratch to the panel underneath the boot lid Rear beam has camber, but you can still get your hand between the wheels and body of the car. Beam shows signs of rusting on the tube, paint has flaked off but the arms move freely Painted the wing mirrors caps to match the car, but they have reacted and the drivers side has creased and the passenger side has cracked Passenger side doorcard has some fraying on the fabric from when the car was broken into 2 small chips on the windshield Aircon doesnt work Gearknob gaiter needs replacing, and gear knob feels loose (can be twisted) Drivers side chassis rail needs rubbing down and under sealing, hasnt gone soft Strut tops need replacing ideally, have rust on them, though theyre still fine they do look worse for wear The clocks ideally need replacing, had put blue LEDs in and removed the yellow dye on the back, but the clear plastic front has a crack in it and the blue plug socket has broken during a removal, it still holds the plug but so you know. Also the bulb behind the battery symbol doesnt light up anymore, have tried changing the bulbs but i think the circuit track has been damaged, a few light bulbs dont light up any more either, also the right indicator arrow doesnt light up some times Have also put white needles and phase 3 silver surround on Have just put new handbrake cables, P bushes and rear drum cylinders on, have receipts Has been sat a while so disk have rusted a bit. Drum brakes will need more adjusting. Callipers are CRYING for a lick of paint! Can not be driven away yet as need to finish bleeding brakes TLDR PICS: Drivers front ![]() Drivers rear ![]() Passenger front ![]() Passenger rear ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() RE: GI/WIW: - Mattcheese31 - 10-06-2014 300-400 get more breaking it imo ![]() RE: GI/WIW: - Toms306 - 10-06-2014 As above, but you wont get that breaking it imo, ph3s don't even fetch that these in parts these days. RE: GI/WIW: - Mattcheese31 - 10-06-2014 (10-06-2014, 03:18 PM)Toms306 Wrote: As above, but you wont get that breaking it imo, ph3s don't even fetch that these in parts these days. Tom with all due respect you're wrong, just admit that you're shit at breaking cars ![]() RE: GI/WIW: - bashbarnard - 10-06-2014 Loving those seats!! RE: GI/WIW: - Lolben91 - 10-06-2014 The main issue with breaking this would be the fact the colour isnt very common i find, so the panels are either worth a fortune or nothing Yeah the seats could go for 100, 100 for the full exhaust, complete engine with box might fetch over 100, could keep the nissens rad and maybe the exhaust mani for my sedan and other odds n sods might go for a bit, id just much rather not. But if interest is there then thats the way it would end up going ![]() RE: GI/WIW: - Toms306 - 10-06-2014 (10-06-2014, 04:50 PM)Mattcheese31 Wrote:(10-06-2014, 03:18 PM)Toms306 Wrote: As above, but you wont get that breaking it imo, ph3s don't even fetch that these in parts these days. I'm shit at most things tbf. ![]() I really don't see how you made £370 from a pov ph1!? Was that recently? RE: GI/WIW: - Mattcheese31 - 10-06-2014 (10-06-2014, 08:49 PM)Toms306 Wrote:(10-06-2014, 04:50 PM)Mattcheese31 Wrote:(10-06-2014, 03:18 PM)Toms306 Wrote: As above, but you wont get that breaking it imo, ph3s don't even fetch that these in parts these days. haha call me a liar why don't you? to be fair i kept a list and sold a few bits years after but still . . ![]() ![]() RE: GI/WIW: - Toms306 - 10-06-2014 Years after? I'm talking about now lol! ![]() You could get a grand from a ph3 Meridian 18 months ago. A year ago it was around £500 from a HDi DTurbo hatch. In the last few months things haven't been selling well at all though... RE: GI/WIW: - Poodle - 13-06-2014 (10-06-2014, 09:05 PM)Mattcheese31 Wrote: haha call me a liar why don't you? to be fair i kept a list and sold a few bits years after but still . . Alright, i call bs. :p No way would you get over £500 for breaking a pov spec ph1 these days, not unless it was completely mint and even then... Free bump. ![]() RE: GI/WIW: - Mattcheese31 - 13-06-2014 (13-06-2014, 05:46 AM)Poodle Wrote:(10-06-2014, 09:05 PM)Mattcheese31 Wrote: haha call me a liar why don't you? to be fair i kept a list and sold a few bits years after but still . . it was bosched and T2, i'll see if i've still got the list lol x |
