| Anyone using these? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Anyone using these? (/showthread.php?tid=24500) |
| Anyone using these? - thebluepearl - 07-06-2014 Hi, any of you out there using any of these on their car? Sound deadening and exhaust RE: Anyone using these? - Curt - 07-06-2014 I've used silent coat in my last 3 cars, it's good stuff. I believe there's a few running the Hoffman exhausts, C.A.R for one IIRC. RE: Anyone using these? - John1.4 - 07-06-2014 not a hoffman but i've got a sportex centre section which is pretty much identical, with a standard backbox it made it sound deeper and gave a rasp to it, was gonna get some dynamat to line the car with to replace the rubbish carpet underlay stuff in the boot, (the stuff above looks like a cheaper kind of similar product) RE: Anyone using these? - Lolben91 - 07-06-2014 Hoffmann tube is alright, have one on my DT. Only issue i have is that my clamps might be a bit too small as the curved part of the pipe would drop down a bit after a short while and scrape more than it should. Other than that is knocks a few RPMs of lag off the turbo spool Anyone using these? - Razorback_Rob - 08-06-2014 I have Hoffman mid pipe. All is good but as said above me, hangs a bit low because the hanger attacher isn't where you'd expect no problems I've ever had except a harsh terrain drive I go up it scrape on but for normal use no problem. RE: Anyone using these? - Poodle - 08-06-2014 The hoffman exhausts are pretty poorly made from what i've seen and heard, but then again at £45 for a straight through mid-section... RE: Anyone using these? - RetroPug - 08-06-2014 If that's genuine silent coat it works well if you use it as intended (as deadening/weighting panels). RE: Anyone using these? - Toms306 - 08-06-2014 (08-06-2014, 06:45 AM)Poodle Wrote: The hoffman exhausts are pretty poorly made from what i've seen and heard, but then again at £45 for a straight through mid-section... This... Not the best quality and certainly not made to spec with hangers etc. But for the price they're alright. Had a decat from them for both a HDi and PD engine. Not actually had the de-mid pipe but Id imagine it'll be the same lol. |
