Specific Spacers - Printable Version
+--- Forum: Misc & Wanted (https://www.306oc.co.uk/forum/forumdisplay.php?fid=14)
+--- Thread: Specific Spacers (/showthread.php?tid=24383)
Specific Spacers - Kezzieboy - 01-06-2014
Was gonna chuck this in my other thread, but it's a bit of a different request.
What I'm looking for are 15/20/25mm spacers, but the stipulation is that the outer spigot, that the wheel sits on must have an internal diameter less than 57mm.
Aside from that, they just need to be 4x108. Bolt on or bolt through are fine, preferably with associated bolts, but that's not crucial.
Cheers!
Specific Spacers - Sambarker - 01-06-2014
Got a feeling you'll be lucky to find off the shelf spacers for that
The peugeot-ford spacers drop the centre bore from 65.1 to 63.4 I think but haven't seen any spacers that drop lower than that for 4x108
And the dodgy wolfrace spacers leave you with a centre bore of 70+mm
Perhaps you could get some 65.1 to 65.1 hubcentric and if there's enough material get someone with a lathe to machine them down?
Or get the centre bore of whatever wheels you want to fit enlarged?
RE: Specific Spacers - Piggy - 01-06-2014
57mm is small.
Need to be accurate too mate or they will be dangerous
RE: Specific Spacers - rd070707 - 01-06-2014
This is interesting, what 4x100 wheels you fitting? Could you not get one with a 57mm outer spigot bored out on the inside to 65.1mm? Or is that what you plan to do?
RE: Specific Spacers - Kezzieboy - 01-06-2014
That's what I'm doing, hence why I said inside diameter not outside diameter Wink I can get them to within 0.05 if not closer piggy, so don't worry about that Smile
My only other option, if I can't find suitable ones in 4x108 is to get 4x100 ones with the right cb and then drill an extra set of holes in them, but that's a bigger ballache than my current plan.
Or someone could find me billet ally for cheap enough and I'll make the bastards things from scratch Tongue
What wheels are they?
Ninja wheels...
Haha oh id love to know. Have you got adapters?
They're 4x108 dude, not 4x100 Smile just need to correct the offset and centre bore and I'll be golden!
So old audi wheels? Haha. Look forward to seeing them on
That's one of the options, not the only one though Wink
RE: Specific Spacers - Kezzieboy - 02-06-2014
Anybody got owt poking around?
