306 - 205 Interchangability - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: 306 - 205 Interchangability (/showthread.php?tid=24183) |
306 - 205 Interchangability - 205steve - 22-05-2014 Ive had a search through the forum using the search function but i cant find what im looking for.....so i appologise if its been answered before.. All im looking to find out, is what if anything can be removed from my donor 306 and fitted on my 205 project, apart from the obvious engine and box. Can the front subframe be fitted ect? Thanks everyone! RE: 306 - 205 Interchangability - welshpug - 22-05-2014 Front and rear dampers, trailing arms, nothing else. RE: 306 - 205 Interchangability - 205steve - 22-05-2014 undefined RE: 306 - 205 Interchangability - bashbarnard - 22-05-2014 steering wheel RE: 306 - 205 Interchangability - pugmanxud - 23-05-2014 Wiper blades
RE: 306 - 205 Interchangability - Jonny81191 - 23-05-2014 battery, light bulbs, radio.... RE: 306 - 205 Interchangability - pugmanxud - 23-05-2014 Dust caps... RE: 306 - 205 Interchangability - 205steve - 23-05-2014 (22-05-2014, 09:49 PM)tombarnard1989 Wrote: steering wheel no need for it as i have a sparco one (23-05-2014, 06:03 AM)Jonny81191 Wrote: battery, light bulbs, radio.... no need for a radio in a track car lol RE: 306 - 205 Interchangability - powerandtorque - 23-05-2014 Depends on the donor as to whether it's an "upgrade", but front brakes are same fitment between 306's and 205's (except for a 1.6 GTi which uses different offset hubs/disks). Wheels are same fitment and offset for a given diameter, although tires are a slightly taller profile on a 306. Plenty of smaller bits that are interchangeable between the cars, but equally, plenty of bits that aren't or that do interchange but aren't quite right (eg 306 front hubs give positive camber on a 205) My 205 is like a frankenstein car with bits of various 205's, 309's, 306's, Xsara's, ZX's, C5's etc on it - originality for the concours lot it is must certainly not
RE: 306 - 205 Interchangability - 205steve - 23-05-2014 Thanks, i have massive brake fitted tere is about 3mm gap between the caliper and wheel |
