1.8 backbox on gti 6 - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: 1.8 backbox on gti 6 (/showthread.php?tid=24157) |
1.8 backbox on gti 6 - webby - 21-05-2014 Hi all, an easy one for you, will a performance backbox off a 1.8 fit on a gti 6? Had one come up local I just need to check it fits. Thanks Andy RE: 1.8 backbox on gti 6 - Eeyore - 21-05-2014 Ive fitted a gti6 backbox to my 1.8. The difference in the exhausts is the manifold and the cat. Rest back from that should be interchangeable. RE: 1.8 backbox on gti 6 - webby - 21-05-2014 Thanks much appreciated, will get that then. RE: 1.8 backbox on gti 6 - C.A.R. - 21-05-2014 (21-05-2014, 11:23 AM)SRowell Wrote: Ive fitted a gti6 backbox to my 1.8. The difference in the exhausts is the manifold and the cat. Rest back from that should be interchangeable. Only the backbox is interchangeable, mid-pipe is different as it starts slightly further back I believe. RE: 1.8 backbox on gti 6 - Eeyore - 21-05-2014 (21-05-2014, 01:53 PM)C.A.R. Wrote:(21-05-2014, 11:23 AM)SRowell Wrote: Ive fitted a gti6 backbox to my 1.8. The difference in the exhausts is the manifold and the cat. Rest back from that should be interchangeable. It was my understanding that it worked like this... 1800 |-Manifold-|----Cat----|-----Centre-----|-Back-| GTI6 |---Manifold---|--Cat--|-----Centre-----|-Back-| RE: 1.8 backbox on gti 6 - webby - 21-05-2014 So going off this the backbox will be ok on my gti 6 ? Thanks Andy RE: 1.8 backbox on gti 6 - Eeyore - 22-05-2014 Yes backbox is fine. RE: 1.8 backbox on gti 6 - webby - 23-05-2014 Spot on, thanks for the help. RE: 1.8 backbox on gti 6 - Grant - 23-05-2014 (21-05-2014, 01:53 PM)C.A.R. Wrote:(21-05-2014, 11:23 AM)SRowell Wrote: Ive fitted a gti6 backbox to my 1.8. The difference in the exhausts is the manifold and the cat. Rest back from that should be interchangeable. Incorrect. The centre and back boxes are the same. It's inly the lengt of the cat going up to the manifold that differs ![]() RE: 1.8 backbox on gti 6 - C.A.R. - 23-05-2014 (21-05-2014, 06:01 PM)SRowell Wrote:(21-05-2014, 01:53 PM)C.A.R. Wrote:(21-05-2014, 11:23 AM)SRowell Wrote: Ive fitted a gti6 backbox to my 1.8. The difference in the exhausts is the manifold and the cat. Rest back from that should be interchangeable. I think the join is in roughly the same place but the two don't mate up iirc. Certainly they are under different part numbers and the middle silencer is smaller on the GTi6, perhaps the pipe diameter is bigger too? Certainly looks like the 1.8 flares out slightly before the backbox join... RE: 1.8 backbox on gti 6 - Grant - 23-05-2014 I had a 1.8 centre and backbox running off a gti cat and manifold for about 18 months. Maybe some are different to others.... |
