Tyre psi - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Tyre psi (/showthread.php?tid=24075) |
Tyre psi - LewisG - 16-05-2014 What psi would you recommend for cyclones on an estate? RE: Tyre psi - Grant - 16-05-2014 I run my hatch on 35 psi. Should be in your book somewhere ![]() RE: Tyre psi - Frosty - 16-05-2014 As grant says about 35/36 psi. It sound say on the drivers door RE: Tyre psi - Piggy - 16-05-2014 35/36 is quite high. I run my fronts at 33 and rears at 32 and Im seeing the centres wearing a little, which indicates too high pressure. Tyre psi - DavidA - 16-05-2014 It says 2.5 bar which is 35 psi on my hatchback. RE: Tyre psi - Ricky - 16-05-2014 Depends on the tyre and the size really RE: Tyre psi - LewisG - 16-05-2014 It does say on the door 2.4 bar but that's the original tyres isn't it RE: Tyre psi - Mattcheese31 - 16-05-2014 32psi on 14's and 35-36 on 15's is the Haynes book figures iirc . . . . .and i don't get and centre wear, go figure . . ![]() |
