306 hdi clicking noise psssenger side below glove box - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: 306 hdi clicking noise psssenger side below glove box (/showthread.php?tid=23879) |
306 hdi clicking noise psssenger side below glove box - ady_c - 07-05-2014 As above it happens when you turn the ignition on once engine is running clicking stops RE: 306 hdi clicking noise psssenger side below glove box - Mattinthehat - 09-05-2014 I have the exact same issue but it stops after a few secs - once the engine has kicked over the clicking starts for a few seconds again. Someone said it was a relay and i have been told to just replace the relay, someone else told me it could be the glow plugs, now its been happening for a while and now the engine takes ages to fire up plus its worse in wet weather! Think im going to replace my plugs this weekend and see if it makes a difference RE: 306 hdi clicking noise psssenger side below glove box - Mattinthehat - 11-05-2014 Right i have an answer for clicking in the glove box!! Turns out all it is is the air con that needs re-gassing :-) My starting issue however seems to be the plugs cos it bumps starts fine straight away meaning its an electrical fault - likley to be the plugs and apparently diesels are not fond of wet weather starts... RE: 306 hdi clicking noise psssenger side below glove box - Mattinthehat - 28-05-2014 i stand corrected... http://306oc.co.uk/forum/thread-23741.html RE: 306 hdi clicking noise psssenger side below glove box - Eeyore - 28-05-2014 Its the air bag... she gunna blow D: |
