Replacing intake elbow gasket - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Replacing intake elbow gasket (/showthread.php?tid=23675) |
Replacing intake elbow gasket - C.A.R. - 29-04-2014 I've spotted what looks like oil spray on the bulkhead just along from the EGR valve. I'm worried that the previous owner hasn't fitted the inlet elbow back with a proper seal, and it might have a little boost leak there? A new one was put on with a take-off for a gauge. I've bought a new gasket, but have heard that this job is a bit of a bastard? Any tips before I embark on it this weekend? Boost gauge only hits 11psi peak, on a stage 1+, which I'm told is too low really... RE: Replacing intake elbow gasket - madmadmax - 30-04-2014 ye part number 0348 N6 64p RE: Replacing intake elbow gasket - DeeTurbo - 30-04-2014 I wouldn't bother with the peugeot gasket, they're too thin to use there as they always leak. I would ether use a good liquid gasket or make a gasket out of an old cereal box. RE: Replacing intake elbow gasket - MIKE-FORD - 06-05-2014 Mine stage 1 with problems and hitting just below 15psi so yeah your low bud and I have the same problem with splutter, one the reasons I'm buying a low mileage engine and doing a bit of work to it been out the engine bay and able to get to that part along with the turbo before I chuck it in |
