oil cooler - Printable Version
+--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10)
+--- Thread: oil cooler (/showthread.php?tid=23584)
oil cooler - tuttyboy84 - 26-04-2014
When the oil cooler fails do you loose coolant and is it a easy job to change it
RE: oil cooler - Toms306 - 26-04-2014
Could do, usually mixes coolant and oil.
Easy enough to change yeah, its just held on by one bolt that the oil filter screws onto.
RE: oil cooler - tuttyboy84 - 26-04-2014
Ive got the oil and water mixing and a little coolant loss and the water light keeps coming on when its full up and thats really enoying
RE: oil cooler - Toms306 - 27-04-2014
Well water light coming on full will be the sensor in the header tank tbh.
Its possible the oil cooler could cause the other problems though. It could also be headgasket but I've never seen a HG fail on 306 HDi's!
oil cooler - Kwik - 27-04-2014
My head gasket is gone on my new one. Combustion to coolant only though
RE: oil cooler - tuttyboy84 - 27-04-2014
Im thinking as there is some sludge in the header tank has some how runed the sensor
(27-04-2014, 02:44 PM)Kwik Wrote: My head gasket is gone on my new one. Combustion to coolant only though
Seriously? Speechless Damn, that's unlucky. Sad As said not seen another!
RE: oil cooler - tuttyboy84 - 30-04-2014
Can I take the original oil cooler off and use a aftermarket one or do I need a working standard one???
oil cooler - Kwik - 30-04-2014
Ecp sell one?
