Would these wheels fit - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Would these wheels fit (/showthread.php?tid=23372) |
Would these wheels fit - Moh - 19-04-2014 Would these wheels fit 17x7" ET: 38 center bore: 65mm RE: Would these wheels fit - Kezzieboy - 19-04-2014 You'd need 20mm spacers, assuming the stud pattern is correct. Bore is technically 65.1, but that shouldn't make any difference RE: Would these wheels fit - C.A.R. - 19-04-2014 That sounds like Ford fitment, similar to what my old OZs were but in 16". 20mm spacers minimum, mine were on 26mm... RE: Would these wheels fit - Connor - 19-04-2014 Ford centre bore is bigger than that though? 76mm comes to mind? RE: Would these wheels fit - Moh - 20-04-2014 How much do spacers cost on average? And how safe are they I tend to do a lot of millege as I'm always up and down the country so I want my car to be safe RE: Would these wheels fit - titch - 20-04-2014 Ford centre bore is smaller, pug is 65.1mm and Ford is 63.4 ish But the Et 38 offset is more like Ford. |
