gti6 tensioner help - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: gti6 tensioner help (/showthread.php?tid=23348) |
gti6 tensioner help - martyn92 - 18-04-2014 I've put on the 136 cambelt kit but I can't work out what I'm doing wrong with the the tensioner. I get the tension right and tighten up the 13mm bolt but the tensioner just moves freely. The 13mm bolt is tight! Any reason why it would be still be loose ? Cheers RE: gti6 tensioner help - martyn92 - 18-04-2014 Okay so the dowel had come loose. So I took the dowel out and threadlocked it. Put it back in and when I tighten up the 13mm bolt the tensioner just swings free again!?! |
