XUD Conversion Question. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: XUD Conversion Question. (/showthread.php?tid=23098) |
XUD Conversion Question. - Danny Wideboy - 11-04-2014 So it looks like the blaze is for the chop,still got a dodgy front end even after all new components and now the heater matrix has gone. I have a silver 1.4 outside with low miles,no rust, but a few dings and too many doors. Also access to a silver 5 door HDI that is tattier still, has dodgy electrics ,unknown to me and somebody tried to steal it and messed up the ignition. I want to put my XUD into one of these and was wondering which would be easiest to do? Would prefer the petrol as it's tidier. Do I still have to take the dash out of the 1.4 to get clocks/guages working or not? Im aware of the fuel tank and filler neck, its the clocks that bother me,if I have to take out the dash I am not gonna bother. Cheers,Danny. RE: XUD Conversion Question. - Piggy - 11-04-2014 Remove the steering column surround. (3screws) Remove the shroud around the clocks (4screws) Remove the 3 screws holding the clocks in. Unplug and remove clocks. Refit ph2 dturbo clocks if its a ph2/3 car or ph1 dturbo clocks if its a ph1 car RE: XUD Conversion Question. - Danny Wideboy - 11-04-2014 Cool so clocks are easy enough then. Cheers Piggy. Just thought about the fact the 1.4 is ECU controlled,will that cause me issues? Cheers,Danny. RE: XUD Conversion Question. - 1616six - 11-04-2014 No, my HDI was ECU controlled but XUD was plug & play. Just need to plug the XUD engine loom into the NSF inner wing plugs. RE: XUD Conversion Question. - Danny Wideboy - 11-04-2014 Nice. Cheers for that. Gonna be a busy boy again then. |
