Will speedlines fit - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Will speedlines fit (/showthread.php?tid=23048) |
Will speedlines fit - camoturd - 09-04-2014 Will speed line peugeot 205 gti 15 inch alloys fit 195/50/15 without spacers at all RE: Will speedlines fit - zx_volcane - 09-04-2014 on a 306? yes will fit fine RE: Will speedlines fit - powerandtorque - 09-04-2014 Straight fit as said above - the speedo will over-read a little due to the smaller tire size but it's not an issue. I'm running them on my 306 HDi hatch as I've loads of those wheels kicking around and I reckon they look pretty good. They'll clear standard HDi 266mm brakes fine, but if you've got 283mm GTi-6 brakes check that the wheel weights aren't on the inside of the wheel as they'll foul the calipers if they are due to clearance being very tight. RE: Will speedlines fit - camoturd - 09-04-2014 Thanks alot guys as just got some for free lol RE: Will speedlines fit - Mattcheese31 - 09-04-2014 it is tight on 283's with wheel weights it's true, shaves them down in the end though so all good . . ![]() RE: Will speedlines fit - powerandtorque - 09-04-2014 (09-04-2014, 01:23 PM)camoturd Wrote: Thanks alot guys as just got some for free lol Free is always the best price for these things ![]() |
