Rear water housing. - Printable Version
+--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11)
+--- Thread: Rear water housing. (/showthread.php?tid=22809)
Rear water housing. - ConorTRG - 02-04-2014
Does anyone know the part number for the rear water housing on the back of the block on the timing belt end, it has a couple of water pipes going into it.
One on mine is plastic does anyone know if there is any alloy ones on the other engines?
Cheers.
RE: Rear water housing. - anto - 02-04-2014
Think someone else mentioned that the S16 had an alloy casing.
RE: Rear water housing. - ConorTRG - 02-04-2014
I'll have to look it up on servicebox this evening then, cheers anto.
It was in the VNT 208bhp project thread that I seen it mentioned I think.
Must have a look through it later.
RE: Rear water housing. - ConorTRG - 09-04-2014
Bump, has anyone a part number for the s16 housing?
