Recomend some brakes - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Recomend some brakes (/showthread.php?tid=22772) |
Recomend some brakes - ct-hdi - 01-04-2014 Right, my HDi is needing some new brakes all round... GTi6 upgrade is out of the question as ive got wheels that wont clear them without grinding a caliper and that to me is a rough as a bears arse way of making it work... I used to run Tarox G88's with Ferodo DS2500's and tbh that was an epic setup... But its overkill for what my HDi runs at daily.. I don't want to spend much so I aren't expecting them to match that setup, but can anyone recommend some that are a slight improvement over a standard set.. or even just a really good set of standard brakes... Thanks RE: Recomend some brakes - Rippthrough - 01-04-2014 I've got some nice 266mm, 54mm pistoned 307 calipers, low milage discs, braided hoses and Bluestuff NDX endurance pads (loads of life left) up for sale as a set... RE: Recomend some brakes - ct-hdi - 01-04-2014 (01-04-2014, 04:33 PM)Rippthrough Wrote: I've got some nice 266mm, 54mm pistoned 307 calipers, low milage discs, braided hoses and Bluestuff NDX endurance pads (loads of life left) up for sale as a set... 266mm what are they same as (if they are same as any 306 model) also, how much RE: Recomend some brakes - Rippthrough - 01-04-2014 They're not the same as the 306 calipers, they're a bit bigger and sit 10mm further back so plenty of wheel clearance, etc. Recomend some brakes - Razorback_Rob - 02-04-2014 C4 vtr ones might be an upgrade. Still 266mm but better braking application I think. |
