Pas Question - Printable Version
+--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19)
+--- Thread: Pas Question (/showthread.php?tid=22747)
Pas Question - Lwilliams - 31-03-2014
Anyone know why the pas return fluid runs around the front of the car, then just U-turns and goes back....Huh
I'm guessing something to do with cooling the fluid?
RE: Pas Question - Slam Wagon - 31-03-2014
Exactly that afaik.
RE: Pas Question - Toms306 - 31-03-2014
Yup, its only there for cooling. Smile
RE: Pas Question - Curt - 31-03-2014
Moved to the correct section.
Re: Pas Question - kentiiboii - 31-03-2014
I'd there any problems to do with bypassing this?
My '6 has it bypassed, I have one but I just really cba getting bumper off again Undecided
RE: Pas Question - Lwilliams - 01-04-2014
Exactly what I was thinking of doing tbh... I can't see it getting that hot really...
RE: Pas Question - cully - 01-04-2014
ive bypassed it in my 6 as the pipe was rusty Wink
RE: Pas Question - powerandtorque - 01-04-2014
Should be absolutely fine running it bypassed.
Only time you're likely to possibly run into issues is if you're doing something like an extended autoslalom on a hot summers day where you'll possibly end up boiling the fluid and losing assistance, but certainly it'll be fine for road and light trackday use.
Whilst it's admittedly a lighter car and thus less demanding on the PAS, I've run without the cooling loop on all my 205's when I've had PAS as the cooling loop sits underneath the passenger floorpan on those and hence is prone for getting damaged or rusting away.
RE: Pas Question - Anton - 01-04-2014
I'm not so sure.... After a long stint on a motorway at xxx I boiled my fluid.
