HDi non-starter (makes a change in this section ;) ) - Printable Version
+--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10)
+--- Thread: HDi non-starter (makes a change in this section ;) ) (/showthread.php?tid=22657)
HDi non-starter (makes a change in this section ;) ) - Toms306 - 29-03-2014
Right,
The estate still wont start and I'm pretty confused now.
Fault on PP2K is cam/crank sync.
It was jumping between yes and no on the live data for cam/crank sync when revved to about 3.5k where it juddered like mad.
Now doesn't start at all, same fault on PP2k.
Fitted known working cam and crank sensors and no difference.
Any ideas as to what to try next?
Cheers
Tom
RE: HDi non-starter (makes a change in this section ;) ) - Slam Wagon - 29-03-2014
Timing
I did have this fault on mine when i went to see steve for my remap the other day. But live data just said yes as it didnt cause any further problems. Not much help i know.
RE: HDi non-starter (makes a change in this section ;) ) - pro_steve - 29-03-2014
The timing must be out, or possibly something simpler like a wiring fault?
If it wasn't running nice I would image the timing belt has jumped a notch
RE: HDi non-starter (makes a change in this section ;) ) - Toms306 - 29-03-2014
It was running perfect for a very brief time between messing about and throwing codes....even revved to the redline and sat there happy enough so the timing is ok.
It's looking like a wiring fault, but I wouldn't have a clue where to start with it. Did check the ECU plug for water ingress but that's fine. Also left the bonnet open in the sun all day to dry out any water that might've been there, to no avail.
Is there anything specific I can check with PP to pinpoint the problem? All I've done is a global test and fault read so far tbh. And watched live engine data.
First night (wouldn't start until I cleared codes, then this) -
https://www.youtube.com/watch?v=F9OKJnz5Ogg
Next morning - fine, though a little smoke blowing through the window lol
https://www.youtube.com/watch?v=8lEA0vPWrdM&feature=youtu.be
Left it idling while I walked to the garage, it cut out and hasn't started since.
https://www.youtube.com/watch?v=qemy-bYclrs&feature=youtu.be
Weird! Confused
RE: HDi non-starter (makes a change in this section ;) ) - DeeTurbo - 29-03-2014
Check the resistance between the pins on the crank and cam to the corresponding pins on the ECU.
JamesG had an issue with a cable on the back end of the cam sensor plug that caused a starting issue on his a couple of years back.
Hmm, that sounds difficult lol, how would I know which pins are which? And what the resistance should be?
Resistance should be very low, if it's high then there could be a bad connection somewhere.
I found today the the main engine loom plug on my hatchback doesn't screw to the body, very strange. I took it off today to check if there were any corrosion in there.
The pins the ecu end should be in the haynes manual, shit is it a three plug ecu on that? If it is I think Cully did a thread in the guides section on the pin outs on the three plug unit.
Ah yeah, makes sense about the resistance!
And yeah it's a Y plate so 3 plug. Confused
Yeah, try a continuity check on the pins and try wiggling the wires the sensor end.
RE: HDi non-starter (makes a change in this section ;) ) - happypug - 31-03-2014
Hi mate.
Just been viewing the you tube vid. Was your engine stone cold when trying to start, if so I noticed your glow plugs where not working. You need the glow plugs to start first thing in the morning as diesel is slow to burn and needs a bit of heat to start. I changed the G/low plug relay on mine at the back of the battery box, a pig of a job as you need to remove the tray as well. Maybe this will help.
RE: HDi non-starter (makes a change in this section ;) ) - Toms306 - 31-03-2014
No it wasn't stone cold, it had been running (hence no glow plug light). Smile.
You don't need glow plugs on a HDi anyway, it will start without them, just takes an extra couple of turns and will be a bit smokier. The plugs actually work without the light on also before people say theirs starts fine without lol.
RE: HDi non-starter (makes a change in this section ;) ) - Toms306 - 02-04-2014
Just to update...this is running now.... When I refitted the crank sensor plug I didn't fully push it in. Itwasntme
So was either the cam or crank sensor as I replaced both at the same time. No faults at all on PP2K now. Big Grin
However it did decide it wanted to be an XUD... Confused Was quite surprised as I'd never seen that sort of temp on a HDi... Guessing it's because I left the rad cap off so there was no pressure to blow the sensor out though lol. Ive just stuck it in with gasket sealant lol.
[Image: IMAG3427_zpscbdd991f.jpg]
Also note the lack of milage display, no idea how that's broken lol!
RE: HDi non-starter (makes a change in this section ;) ) - DeeTurbo - 02-04-2014
Could the lack of mileage display be the back light bulb?
(02-04-2014, 08:29 PM)DeeTurbo Wrote: Could the lack of mileage display be the back light bulb?
Don't think so. As when the time/temp bulbs blow you can see it from certain angles. Cant see this at all! Could try the bulb though.
Try shining a torch into it and see if you can see any number?
RE: HDi non-starter (makes a change in this section ;) ) - C2K - 04-04-2014
Blown fuse takes out the mileage. If the time click is out too look at the fuse, 28 I think but check my threads.
RE: HDi non-starter (makes a change in this section ;) ) - Toms306 - 04-04-2014
Time clock works fine... Confused
Think its a lose connection somewhere as half the bulbs only work after whacking the clocks. lol
