Pitted Trail arm shaft - Printable Version
+--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19)
+--- Thread: Pitted Trail arm shaft (/showthread.php?tid=22320)
Pitted Trail arm shaft - pugtk - 19-03-2014
I've a very slightly pitted trail arm shaft, probably could just stick it back together, but I don't want to wreak new bearings in a couple of months. would chemical metal be good enough just to fill the small imperfections and then polish it up?
RE: Pitted Trail arm shaft - welshpug - 19-03-2014
unlikely it'll be strong enough, shaft and a bearing kit is only £40 or so on ebay.
RE: Pitted Trail arm shaft - Grant - 19-03-2014
Chemical metal will just ruin new bearings quicker than the worn shaft will.
Get a rebuild kit like this. Will definitely be a trustworthy beam then...
