I hace some cuestions of my car - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: I hace some cuestions of my car (/showthread.php?tid=22238) |
I hace some cuestions of my car - werty100 - 16-03-2014 Hi i am a new owner of 306 diesel model of 96. What phase it is? Is normal to have vibration when you power it on...? How can i bost my engine for free?? RE: I hace some cuestions of my car - Mattcheese31 - 16-03-2014 Welcome to the club, you probably have a phase 1, have a look in the guides section for tuning advice ![]() RE: I hace some cuestions of my car - 306pc - 16-03-2014 Hi, I had vibrations while accelerating, it was a bolt missing from the fuel pump bracket, easy fix. For boost, type "stage 1 tune" into YouTube Darrenjlobb has a great video many people have used. RE: I hace some cuestions of my car - Tom - 16-03-2014 96 is most probably a phase one as said above. Vibrations when accelerating could be engine mounts, a loose bolt, maybe something rubbing on the chassis. Could be a whole host of things, you will need to look into that one on your own. And tuning get on youtube theres a few videos on there, or search around on here and google. Re: I hace some cuestions of my car - kentiiboii - 16-03-2014 Threw afew phase 2 p reg too. Re: RE: I hace some cuestions of my car - werty100 - 17-03-2014 (16-03-2014, 09:36 PM)Tom Wrote: 96 is most probably a phase one as said above. Problem only is present when i power on the car witout accelerating it... This car have ecu port for be sure is not a electrical problem or other thing RE: I hace some cuestions of my car - Tom - 17-03-2014 96 is more than likely XUD not hdi. Which means it has no ecu and is mechanically controlled. I would say its an engine mount, i would start by checking the lower mount. |
