Clock bulbs - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: Clock bulbs (/showthread.php?tid=22118) |
Clock bulbs - philpemberton94 - 12-03-2014 Just wondering what bulbs are used in the clock/temperature display in the centre console, mine are buggered! Cheers, Phil RE: Clock bulbs - Bnmtuning - 13-03-2014 They're the same bulbs that are used in behind the dash bud not sure what size they call them, you could change them for blue bulbs like mine. But make sure you remove the yellow film and replace with a white film ( behind the clock) avoid cheap ebay ones as they tend to stop working or start flickering after a short while
Clock bulbs - liam - 14-03-2014 Bump. Mine went after I installed a head unit. How do you get the clock out? Simply pry it out with a screwdriver? RE: Clock bulbs - Nathan1305 - 14-03-2014 (14-03-2014, 04:37 PM)liam Wrote: Bump. Mine went after I installed a head unit. How do you get the clock out? Simply pry it out with a screwdriver? Simply remove the plastic facia around the clock display and you will see two torx screws. Remove them and unplug the wires going into the clock I did mine yesterday it's really easy
RE: Clock bulbs - DazzaHDI - 14-03-2014 (13-03-2014, 08:39 AM)Bnmtuning Wrote: They're the same bulbs that are used in behind the dash bud not sure what size they call them, you could change them for blue bulbs like mine. But make sure you remove the yellow film and replace with a white film ( behind the clock) avoid cheap ebay ones as they tend to stop working or start flickering after a short while You got a link for these blue bulbs? I've got them in mine but for some reason sometimes the one stays off -_- RE: Clock bulbs - Seb_Ryan - 14-03-2014 T5 wedge bulbs iirc Clock bulbs - liam - 25-03-2014 Now I don't know what colour to go for xD |
