Cooling fan, no low speed. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: Cooling fan, no low speed. (/showthread.php?tid=21810) |
Cooling fan, no low speed. - Tom - 01-03-2014 Righto lads and ladies, My friend Ryan with the phase one six only has a high speed fan on his radiator. Or should i say the fan only comes on at 105degrees and thats pretty darn hot. I had a look at the relays and they looked ok, i think i tested them but i cant remember. He only has physically one fan there (isnt is AC models that have 2?) But yeah i think thats it. How do we go about sorting it? Or what does the ecu go off to trigger the different fan speeds? RE: Cooling fan, no low speed. - Paul_13 - 01-03-2014 You'll need to get a lower temp rad switch. It's behind the passenger headlight and screws into the rad RE: Cooling fan, no low speed. - Tom - 01-03-2014 (01-03-2014, 09:37 PM)Paul_13 Wrote: You'll need to get a lower temp rad switch. Does the '6 not have a low speed and high speed fan setting? RE: Cooling fan, no low speed. - j_carter - 01-03-2014 Just one speed setting on mine, although they are aftermarket fans. RE: Cooling fan, no low speed. - Paul_13 - 02-03-2014 It may be the same set up as the 205.it'll have a high/low speed resistor and they're all buggered. Just get a lower temp rad switch so the fans come on earlier RE: Cooling fan, no low speed. - Tom - 21-04-2014 Bump. We were talking about this the other day, he wants to put a switch in but i think it would be better if we could get the factory set up working properly, anyone got a '6 that knows whats spose to happen? RE: Cooling fan, no low speed. - C2K - 21-04-2014 I had this. Bottom loom connector will be corroded, and the series 12v fan positive is broken (you can check voltage, theres an faq). When stage 2 kicks in at 105 the relays change to engage parallel fan operation, the second live switching in starts the second fan. I ran a separate 12v to the relay from the battery with a fuse inline, still worked 5 years later. Guide: http://306oc.co.uk/forum/thread-5185.html My issue with pic: http://www.306gti6.com/forum/showthread.php?id=119690 RE: Cooling fan, no low speed. - Tom - 21-04-2014 Hmm i forgot about that loom connector! Will have to get in there and see how it looks! Thanks bud will report back with whats going on. RE: Cooling fan, no low speed. - welshpug - 21-04-2014 if its non ac then it will have or should have a resistor for the low speed which is clipped where the second fan would sit. RE: Cooling fan, no low speed. - Tom - 27-04-2014 Looking at this now, its non ac so has one relay and one fan and only high speed setting. Attempting to run a switch so its manual but its not going so well either. The resistor in the fan cowling had no resistance when checked with a meter across any of the pins, does that mean its fooked? |
