knocking at front of car - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: knocking at front of car (/showthread.php?tid=21505) |
knocking at front of car - camoturd - 18-02-2014 Hi guys quick question I have a knocking noise from my engine bay on drivers side. The speed of knocking increases on acceleration. What could it be? On a side note I have just done CAMBELT KIT and aux belt tensioner and idler could it be that is knocking RE: knocking at front of car - Mattcheese31 - 19-02-2014 (18-02-2014, 11:45 PM)camoturd Wrote: Hi guys quick question I have a knocking noise from my engine bay on drivers side. The speed of knocking increases on acceleration. What could it be? sounds like it mate, i wouldn't be driving it until you find out tbqh . . RE: knocking at front of car - Poodle - 19-02-2014 Does it increase relative to engine speed or to road speed? RE: knocking at front of car - camoturd - 19-02-2014 Engine speed RE: knocking at front of car - ADV_93 - 19-02-2014 Get light between the engine and inner bay and see if anything is hitting RE: knocking at front of car - camoturd - 19-02-2014 Yeah its is strange if it was anywhere else I would of thought it was a tappet Bit have noticed it starts at about 2500 rpm and dies at 4000 rpm and happens under heavy acceleration RE: knocking at front of car - Piggy - 19-02-2014 Take aux belt off. If noise dissapears then its on the aux setup RE: knocking at front of car - camoturd - 19-02-2014 Ok will do that RE: knocking at front of car - Jimbo - 19-02-2014 Could be.injectors worn on hdi Have a light tapping noise under load up until around 3200rpm usually? I did changed injectors and.noise gone RE: knocking at front of car - camoturd - 19-02-2014 (19-02-2014, 09:48 PM)Jimbo Wrote: Could be.injectors worn on hdi Is that quiet a normal problem then RE: knocking at front of car - Poodle - 20-02-2014 What youre describing sounds nothing like injectors. It doesn't sound good though, is your crank pulley all good? RE: knocking at front of car - camoturd - 20-02-2014 No idea how to tell if it's not RE: knocking at front of car - E_KEL95 - 20-02-2014 Sorry for the thread hijack but ive a knock from my front drivers well when turning, theres a couple of wee knocks when youve the wheel turned fully right and turning tight ie swinging the car round in a carpark my initial thought was droplinks? RE: knocking at front of car - andywhy - 20-02-2014 Could be CV joint if it only happens when turning. RE: knocking at front of car - C2K - 20-02-2014 Crank pulley yo. RE: knocking at front of car - camoturd - 20-02-2014 (20-02-2014, 12:15 PM)C2K Wrote: Crank pulley yo. So are you saying it could be the crank pulley then? RE: knocking at front of car - Poodle - 20-02-2014 Get the drivers side in the air and take the front wheel off. Have a look at the pulley with the engine running, if its knackered it'll wobble or run off-centre, there'll probably be rust marks and perishing too. RE: knocking at front of car - camoturd - 20-02-2014 (20-02-2014, 04:35 PM)Poodle Wrote: Get the drivers side in the air and take the front wheel off. Have a look at the pulley with the engine running, if its knackered it'll wobble or run off-centre, there'll probably be rust marks and perishing too. Ah fair enough I will do that when I change the wheels over as it 9 nay started after doing the aux tensioner and idler so it could be the crank pully as I changed the bolt that holds it on but not the pulley it's self |
