Where can I get this from? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Where can I get this from? (/showthread.php?tid=21246) |
Where can I get this from? - Bodge - 10-02-2014 I apologise if this is in the wrong section however I was unable to post in the parts wanted section. I've been looking for hours and can't source any of this braided pipe for my break system. ![]() Anyone have any links to where I can purchase some? RE: Where can I get this from? - powerandtorque - 10-02-2014 Any motor factor should be able to supply some vacuum pipe in the appropriate size. RE: Where can I get this from? - Piggy - 10-02-2014 any motor factors, halfords etc I think its 10mm inner, but you may wana measure it. a 5second ebay search resulted in 600+ results for braided 10mm hose heres one http://www.ebay.co.uk/itm/COTTON-BRAIDED-RUBBER-FUEL-PIPE-TUBING-PETROL-DIESEL-LINE-UNLEADED-OIL-HOSE-UK-/161078469777?pt=LH_DefaultDomain_3&var=460196448743&hash=item2581066491 ![]() (PS I assume this is your vacuum hose?) RE: Where can I get this from? - Bodge - 10-02-2014 Cheers guys! I guess I was just searching for the wrong thing Yeh, it's the pipe that connects the vacuum pump to the metal pipe that runs along the bulkhead.
RE: Where can I get this from? - Poodle - 10-02-2014 It's spelt "brake", that might help your search.
RE: Where can I get this from? - Piggy - 10-02-2014 (10-02-2014, 08:13 PM)Poodle Wrote: It's spelt "brake", that might help your search. I was guna point that out...but Im trying to break habits! RE: Where can I get this from? - Poodle - 10-02-2014 Didn't read the other responses tbh, just imagined the poor guy had been shouting at ebay because it kept showing him broken pipes when all he wanted was brake hose.
RE: Where can I get this from? - Bodge - 12-02-2014 Not going to start a new thread as I don't want to clutter the board so I was wondering if you guys could help me with finding a few things. I'm going to have a crack at changing the servo myself and the Haynes manual tells me I need to replace a few things but I can't find them anywhere. I'm after a master cylinder 'O' ring, a check valve sealing grommet and a servo mounting gasket. Any help is hugely appreciated! RE: Where can I get this from? - Tom - 12-02-2014 These guys?... Maybe. http://biggred.co.uk/ RE: Where can I get this from? - Dangti6 - 12-02-2014 Make sure it's the appropriate hose you buy. Anything substandard could suck in on itself. |
