not a 306 but a saxo - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: not a 306 but a saxo (/showthread.php?tid=2113) |
not a 306 but a saxo - aggyj17 - 10-03-2012 As said this is not for a 306 but a 1.1 saxo still a TU engine so i hope you guys can help. I am use to working on the XU petrol and diesel engines but never a TU. My question is where is the oil filter located is it on the right hand side of the exhaust manifold? there is a black plastic bottle is the oil filter located there? If so how do you undo it as i dont want to break it. I will go out and get a pic of what i mean thanks Re: not a 306 but a saxo - aggyj17 - 10-03-2012 ![]() Is this my oil filter? Re: not a 306 but a saxo - Midnightclub - 10-03-2012 Yes Re: not a 306 but a saxo - aggyj17 - 10-03-2012 Cheers mate how does it come off? Re: not a 306 but a saxo - 4WayDiablo - 10-03-2012 Screw fit. Pair of mole grips and mash it up if needs be Re: not a 306 but a saxo - Midnightclub - 10-03-2012 Use a socket if you can, it's only plastic so it could snap Re: not a 306 but a saxo - aggyj17 - 10-03-2012 Ok then ill give it a go gotta swap the oil filter now as i got the other sort lol. Thanks for the replys guys Re: not a 306 but a saxo - Chris1357 - 10-03-2012 These things dont snap, They come off real easy.. Re: not a 306 but a saxo - KrisB - 13-03-2012 22mm spanner or socket. I use a nice long extension so can undo with your hand out of the engine bay. Make sure when you get a new filter you get an paper one, not a screw on. I've re-located a fair few of these now / converted to normal filter. |
