Orignal clutch? - Printable Version
+--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10)
+--- Thread: Orignal clutch? (/showthread.php?tid=21076)
Orignal clutch? - Daniel306 - 03-02-2014
Got the gearbox off my 307 tonight, the clutch and DMF was a LUK, did they ever get fitted as standard?
Good thing i went for the valeo SMF conversion, the DMF rotating by about 50mm by hand but its also rocking top to bottom by about 10mm
RE: Orignal clutch? - DeeTurbo - 03-02-2014
Yep, mine was a LUK kit in mine. I've had my car since new.
Re: Orignal clutch? - maffy - 03-02-2014
Sounds like your ready for the smf conversion then!
RE: Orignal clutch? - Daniel306 - 03-02-2014
There was no noticeable problems with the fly, just the clutch was slipping
RE: Orignal clutch? - Toms306 - 04-02-2014
Wasn't the DMF clattery when pressing the clutch with 10mm of in/out movement!? Confused
RE: Orignal clutch? - Daniel306 - 04-02-2014
Surprising no, never noticed anything. was planing to just replace the clutch and pressure plate but this was not much more http://www.ebay.co.uk/itm/110867277566?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
http://www.aussiefrogs.com/forum/archive-common-faults-fixes/107433-peugeot-307-2-0-hdi-136-dual-mass-flywheel-replacement-guide.html
Good guide for the job, its where i got the link for that clutch kit
