Speakers cutting out - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: Speakers cutting out (/showthread.php?tid=20637) |
Speakers cutting out - PugRory - 20-01-2014 My speakers cut out occasionally, but only when I brake? i'm suspecting it might be something to do with the earthing of the speakers, any other things it could possibly be? RE: Speakers cutting out - Grant - 20-01-2014 Check the condition of the loom behind the head u it as well as the door looms. Could well be an earth problem though RE: Speakers cutting out - RetroPug - 20-01-2014 Does anything else happen like dash lights diming? Does the head unit loose power or does it stay on while the sound is cutting out? RE: Speakers cutting out - PugRory - 20-01-2014 Nothing else happens, it's just the speakers that cut out RE: Speakers cutting out - RetroPug - 20-01-2014 Maybe broken wires in the door loom near the plug into the vehicle body where they get tugged around by opening the door. There's a guide to fixing these if this is what the problem is: http://306oc.co.uk/forum/thread-11512.html However, if it is all speakers including the parcel shelf/rears then maybe the loom behind the head unit as grant said? Check for loose connections? RE: Speakers cutting out - PugRory - 20-01-2014 It's all the speakers unfortunately, probably what you said about the head unit then! i'll have a look anyway, cheers for your help! good old French electric ay! |
