Changing Injectors - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Changing Injectors (/showthread.php?tid=20568) |
Changing Injectors - Alan_M - 18-01-2014 As one of my injectors (one closest to the cambelt) is sounding like a machine gun, I'm planning on fitting a refurbed set of 307 injectors. I realise new copper seals (which thickness though?) and clamp nuts are needed, but is there any requirement to clean up/re-cut the injector seats? There are tools available for the job. RE: Changing Injectors - mattgreene - 18-01-2014 When i changed mine i just renewed the copper washers, after i pulled out the injector, i just shone a torch down the hole to check the condition of the seat, they were all fine, if they need a clean try wrapping emery cloth on the end of a screwdriver. RE: Changing Injectors - Uberderv - 19-01-2014 If the original copper washers are ok there is no reason you cant anneal them and re-use. I have never used new clamp nuts either. As above check the seat, it might have a bit of carbon on there (although it shouldnt really) and clean back to aluminium without damaging it. When re-fitting the injectors give the body (under the clamp flats) a light smear of copper grease for easier future removal. |
