Wing replacement - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: Wing replacement (/showthread.php?tid=20203) |
Wing replacement - Whodafunk - 07-01-2014 Someone told me the wings are spot welded in place and require drilling out, is this right? I've done wing before on my 406 coupe and they were just bolted on. RE: Wing replacement - underground375 - 07-01-2014 The later model there is 2 rivets you have to drill out, but they still kept the top 10mm bolt. RE: Wing replacement - Whodafunk - 07-01-2014 Ah, so when re fitting it needs welding back on? RE: Wing replacement - underground375 - 07-01-2014 No all I did was put the wing into place, then put a self tapper where the rivet used to be. The rivet is only small which drills out in seconds. RE: Wing replacement - Whodafunk - 07-01-2014 Ah, cheers. Where are the rivets located? Wing replacement - JamesG - 07-01-2014 (07-01-2014, 02:24 PM)Whodafunk Wrote: Ah, cheers. Where are the rivets located? As you open the bonnet there on the top where the wing goes on inside the side you'll see them RE: Wing replacement - underground375 - 07-01-2014 (07-01-2014, 02:37 PM)JamesG Wrote:(07-01-2014, 02:24 PM)Whodafunk Wrote: Ah, cheers. Where are the rivets located? You cant really miss it when you no where your looking. There normally colour coded to the wing. RE: Wing replacement - cully - 07-01-2014 [attachment=12502] green top of wing is rivets to drill out, red m6 bolts to remove, red/orange m6 bolt to slacken as slots in wing panel, yellow screw for arch liner green lower rivets securing sill trim makes easer wing removal blue sill trim to wing panal clip RE: Wing replacement - Whodafunk - 07-01-2014 Cheers, that's a big help |
