Reverse Light Switch?! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Reverse Light Switch?! (/showthread.php?tid=19673) |
Reverse Light Switch?! - Optikal - 18-12-2013 Alright Chaps! I'm looking for my reverse light switch on an auto 1.8 xu7jp. ![]() As you can see, I've taken off the battery, removed the box and the battery plate as instructed in Haynes. ![]() But then Haynes simply states: Trace the wiring back from the switch to the connector and unplug it. Then unscrew it out of the housing. Simples! But which one is the fecking switch?! Is it this ugly thing here??
RE: Reverse Light Switch?! - Optikal - 18-12-2013 Anyone?? :/ RE: Reverse Light Switch?! - Grant - 18-12-2013 I have no idea about the auto boxes, but on the manuals it is a brown or white plug depending on the age. Get your brakes sorted? RE: Reverse Light Switch?! - Toms306 - 18-12-2013 Reverse light switches are usually only 2 wires, and that looks like 3 so probably isn't. As above though, I'm not clued up on the auto's! RE: Reverse Light Switch?! - Optikal - 18-12-2013 (18-12-2013, 05:41 PM)Grant Wrote: I have no idea about the auto boxes, but on the manuals it is a brown or white plug depending on the age. It's sitting much better now yeah but got it booked into the garage for a full replacement of it's drums before the MOT. Just going through all of its problems one-by-one now... RE: Reverse Light Switch?! - Martin306 - 18-12-2013 Is this an auto? It's probably under the gear selector console. Which is where reverse light switches lurk on most autos. If it makes you feel better, reverse lights don't come into the MOT.
RE: Reverse Light Switch?! - miles - 18-12-2013 It's part of the inhibitor switch, 4 wires where you red line is RE: Reverse Light Switch?! - Optikal - 18-12-2013 (18-12-2013, 06:58 PM)Martin306 Wrote: Is this an auto? Yeah it's an auto. You mean within the car? I've had the selector cover off when i removed the central surround for the handbrake and not noticed anything. I'll hve a better look tomorrow. (18-12-2013, 07:26 PM)miles Wrote: It's part of the inhibitor switch, 4 wires where you red line is Thanks Miles, I think that may be my culprit there then! RE: Reverse Light Switch?! - underground375 - 20-12-2013 Never seen that engine before RE: Reverse Light Switch?! - Eeyore - 20-12-2013 1.8 8V auto! what a beast! RE: Reverse Light Switch?! - Optikal - 23-12-2013 The ladies love it when I'm cruising with the two booster seats in the back... Oh, and an update. The RLS was working fine, it is the sensor in the gear selector that is not working problem (an electric problem in a 306! who'd a thought?!) Gonig to take a look at it some point soon when I have the time to strip back the plastics. |
