Which springs? - Printable Version
+--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19)
+--- Thread: Which springs? (/showthread.php?tid=19487)
Which springs? - Sean - 10-12-2013
Is there any difference between the 1.6/1.8 front springs and the ones on the 1.4? Huh
RE: Which springs? - Piggy - 10-12-2013
I would think so...
the 1.8 is a fair bit heavier than a 1.4
RE: Which springs? - Matt - 10-12-2013
1.4/1.6 not really a difference, same weight in the front, 1.8 spring will be slightly firmer on a 1.4 iirc
RE: Which springs? - underground375 - 10-12-2013
All about engine weight!
RE: Which springs? - Sean - 10-12-2013
The fronts are knackered on my 1.4, so I'm just wondering what I should replace them with. I'm fine with the standard, just making sure they'll fit (ebay is pretty vague as to which models the springs are designed for)
RE: Which springs? - Matt - 11-12-2013
May aswell go lower, they are near same price anyway lol
RE: Which springs? - Sean - 11-12-2013
(11-12-2013, 12:00 AM)Matt Wrote: May aswell go lower, they are near same price anyway lol
Well, the plan is for this to be my commuting car while I work on my nova, but suppose a cheeky 30mm wouldnt hurt. . .^^
RE: Which springs? - puglove - 11-12-2013
If you get lower springs you need ones that are suited to you engine weight I.E 1.4/1.6 springs
