ph3 Xud conversion - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: ph3 Xud conversion (/showthread.php?tid=19417) |
ph3 Xud conversion - Jimbo - 08-12-2013 Hi all, fed up of my hdi cos quite frankly there shit. Just picked up a complete ph1 Dt cheap and im gonna convert it. Few questions : does the engine loom from ph1 just plug in bottom front.passenger side. : does the rev counter still work? Ive got a complete ph1 so everything needed I have. I have no problems swapping engines and getting an xud to run its just I want it too be tidy job Thanks Any input from bigcheez, jj and dan would be appreciated as any other info wud.too RE: ph3 Xud conversion - Piggy - 08-12-2013 use ph1 loom. but will need brown sensor for fans need ph2 clocks RE: ph3 Xud conversion - 1616six - 08-12-2013 Have a look at my old threads for full conversion details, it was over a year ago now but il try and remember.. You'll need to use XUD clocks to get the rev counter to work, everything on the HDI clocks will work bar revs. Passenger inner wing wiring plugs straight in, you'll need the Bitron/bsi unit from the inner wing of the donor car too. We had to use the lower rad pipe & possibly the rad from the xud but I can't honestly remember if it was rad or not. Exhaust just use the cat/decat from the xud, it will bolt straight up to your HDI centre section HTH ![]() (08-12-2013, 07:19 PM)Piggy Wrote: use ph1 loom. Car side? You don't need to touch the loom, unplug both engines at the passenger wing plug, you don't need to change anything else loom wise. RE: ph3 Xud conversion - Piggy - 08-12-2013 ph1 engine loom needs to be ph2 xud clocks, not ph1 oh n xud in tank pickup RE: ph3 Xud conversion - Jimbo - 08-12-2013 Ideal thanks fot help, I knew it was easy just some pointers to help out.etc Yeah as said.already.have got everything I need ![]() Repped ![]() RE: ph3 Xud conversion - Jimbo - 08-12-2013 Did the glow plug relay work?? RE: ph3 Xud conversion - Piggy - 08-12-2013 yup ![]() and I converted a petrol to the 2.1! RE: ph3 Xud conversion - Jimbo - 08-12-2013 So much win Suprised this isnt done more often RE: ph3 Xud conversion - Piggy - 08-12-2013 it was much simpler than I thought to be honest. gota love psa interchangability! rep welcome ![]() RE: ph3 Xud conversion - Jimbo - 08-12-2013 Ahhh go on then RE: ph3 Xud conversion - Piggy - 08-12-2013 well I did answer ya Qs first!! thanks ![]() RE: ph3 Xud conversion - Poodle - 09-12-2013 (08-12-2013, 09:50 PM)Jimbo Wrote: Suprised this isnt done more often Ah that'd be because the HDi is a far superior engine, would have thought that was obvious. :p RE: ph3 Xud conversion - Piggy - 09-12-2013 I hope, pray, train myself, to never give in to the HDi!!! ![]() |
