Govner / MOT - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Govner / MOT (/showthread.php?tid=1914) |
Govner / MOT - doogle-d turbo - 02-03-2012 hi guys, i've got the MOT in a week or so and the car was pumping a fair bit of smoke. However i've just fitted a fmic and most of the fuel seems to be burning now so im fairly happy with sending it in. Only thing is ive had it gov modded and not confident trying to limit the govner or throttle arm. Any1 got any hints, what they did to get their xud through the MOT? Last thing i want is the engine running away. cheers steve Re: Govner / MOT - ginge191 - 02-03-2012 screw down max fuel to the minimum, turn the idle up if it drops? Re: Govner / MOT - Connor - 02-03-2012 Or adjust the throttle stop, so he cant rev it fully Re: Govner / MOT - ginge191 - 02-03-2012 Connor Wrote:Or adjust the throttle stop, so he cant rev it fully i can picture the MOT tester revving and it stopping under 3k and his face :arrow: :|
Re: Govner / MOT - Connor - 02-03-2012 So? Modern cars wont rev past 2k if theyre not moving... Re: Govner / MOT - Ruan - 02-03-2012 My car wouldn't rev past about 3500rpm for the MOT... I stalled it 3 times pulling into the MOT centre... It had THAT little power it couldn't even pull itself up the slightest inclines. The MOT tester even said "God that things gutless like that, you can turn it back up now..." Re: Govner / MOT - ginge191 - 02-03-2012 Connor Wrote:So? Modern cars wont rev past 2k if theyre not moving... i thought when they go in for MOT' they ask for cambelt wear, and rev on redline?? then again, i've never been AT an MOT or a diesel mot for that note.. Re: Govner / MOT - Connor - 02-03-2012 Well they cant redline it if its not moving lol Re: Govner / MOT - Niall - 02-03-2012 Connor Wrote:So? Modern cars wont rev past 2k if theyre not moving... Like what car out of interest? Re: Govner / MOT - mark_airey - 02-03-2012 Neil Wrote:Connor Wrote:So? Modern cars wont rev past 2k if theyre not moving... I know the Nissan Primastar Van won't for a start, also means that the renault traffic won't and the Vauxhall Vivario since they are all effectively the same van......... Re: Govner / MOT - Niall - 02-03-2012 mark_airey Wrote:Neil Wrote:Like what car out of interest? Ah fair enough. Never seen that before. I know my skoda goes to the red line when I'm sitting still!
Re: Govner / MOT - mark_airey - 02-03-2012 Neil Wrote:Ah fair enough. Never seen that before. I know my skoda goes to the red line when I'm sitting still! As said, I think a fair few of the newer engines are like that now! Also @ "Neil"
Re: Govner / MOT - 4WayDiablo - 02-03-2012 I done what connor suggested limited it and turned the fuel down Got 0.00 emissions :-) and only just got to 60 lol Re: Govner / MOT - Midnightclub - 02-03-2012 Quite a few cars with fly by wire throttle will only rev to say 3k then drop back down to idle if you press the brake and the throttle at the same time whilst sat still Re: Govner / MOT - Niall - 02-03-2012 Midnightclub Wrote:Quite a few cars with fly by wire throttle will only rev to say 3k then drop back down to idle if you press the brake and the throttle at the same time whilst sat still Will be trying this in the skoda in a bit
Re: Govner / MOT - doogle-d turbo - 02-03-2012 cheers for the tips ill have a play with it before i take it down, then everythings getting turned up .I noticed yesterday that the hot/cold idle cable from the wax stat is disconnected but i dont seem to have any problems with the idle. A forum member tuned it and set it up when he fitted my bosch, so not sure exactly how tuned it is :/ Re: Govner / MOT - doogle-d turbo - 02-03-2012 just realized this topics in the wrong section. oops Re: Govner / MOT - Dum-Dum - 02-03-2012 Moving to correct section |
