Hearing a screech - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Hearing a screech (/showthread.php?tid=19067) |
Hearing a screech - Matt - 22-11-2013 At high rpm isn't good right? Whist the aa was sorting my car tonight he was revving it, holding and dropping off. As h did it the third time there was a screech which lasted 2/3seconds. Came from block area. RE: Hearing a screech - Tom - 22-11-2013 Could of just been the aux belt. RE: Hearing a screech - Ed Doe - 22-11-2013 It was probably just the local clunge climaxing as you revved your dt tbh xx RE: Hearing a screech - Niall - 22-11-2013 Have you been using the engine as a water pump again? RE: Hearing a screech - Matt - 23-11-2013 I thought aux belt, but I also thought turbo, screech a normal "I'm getting to be f*cked" sound for a turbo to make? RE: Hearing a screech - Tom - 23-11-2013 A turbo would squeel like f*ck underload before it would do it just revving surely? |
