1.9 TD Alternator which one? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: 1.9 TD Alternator which one? (/showthread.php?tid=18715) |
1.9 TD Alternator which one? - Scott_GT - 09-11-2013 Is there any other cars that have the same one. My one only charges the battery when over 2K revs. So looking to get another one. RE: 1.9 TD Alternator which one? - welshpug - 09-11-2013 check the small wire is connected. RE: 1.9 TD Alternator which one? - Scott_GT - 09-11-2013 yes i checked it, and its connected. it does have a cut in the wire about 20 cm back from the alt. and can see the wire, which looks dark. possible problem. suppose i could put a choc bloc in and see what happens, RE: 1.9 TD Alternator which one? - ArbGarry - 09-11-2013 Mine failed a few weeks back, so i got this one, genuine valeo with warrenty http://www.ebay.co.uk/itm/221017878272?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 RE: 1.9 TD Alternator which one? - londondan86 - 10-11-2013 Have a look at the ones from the old 406 xud's. I believe they had a higher rated output.... |
