1.4-1.6 ecu - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: 1.4-1.6 ecu (/showthread.php?tid=18706) |
1.4-1.6 ecu - Carlos vinyls - 08-11-2013 What is the difference between the two ECU as need a new ecu set and the breakers have one but don't know if it's a 1.4 or a 1.6 RE: 1.4-1.6 ecu - John1.4 - 09-11-2013 the map will be different for one, if they're both MPI injection all the pinouts will be the sameish, if not then it wouldn't have the drivers for multiple injectors / knock sensor and some of the sensor values will be different, it would probably run... Badly, best thing is to compare the part numbers and see if they're the same or not |
