Help - Printable Version
+--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19)
+--- Thread: Help (/showthread.php?tid=18655)
Help - Nadine - 06-11-2013
Ok I might be being thick/blonde/stupid or all 3. However I ordered front and rear discs and pads off car parts for less. I put in my reg and ordered the ones that came up. Now they have arrived but on the box of the rear pads, it's says 106/saxo vts and the front say xsara. Have they sent the wrong stuff or do these fit?
RE: Help - Danny2009 - 06-11-2013
If you put your reg in they should be right parts, a lot of 306 stuff fits other French marks
RE: Help - Toms306 - 06-11-2013
The rear pads will be right as they are the same across the range. I'm not sure if the Xsara VTS uses different front brakes to the '6, but just check the pads look the same as the ones that are already fitted.
Putting your reg in ECP/CPFL doesn't guarantee the right parts though, I know for smaller engine cars with 266mm brakes you get all 3 types different types come up when you use a reg! Undecided
RE: Help - Pompey306mark - 06-11-2013
Na you should be ok. Only issue you might have are some front breaks are different ie Lucas or Bosch.
But if you put your registration number in it should be fine.
RE: Help - Nadine - 07-11-2013
ok thanks guys, im hoping they fit as got brand new brakes all round for £60 lol
