Problems with my Xs already - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Problems with my Xs already (/showthread.php?tid=18620) |
Problems with my Xs already - underground375 - 04-11-2013 Hi all had the car for about two days now but ive got engine problems. It's a weird one, when I put my foot down there's no power on the lower rpm, and when it does decide to kick in i get a weird noise! Like the sound of a knackered tensioner. but it only happens under load. Another thing is there is a small miss fire which can be felt when accelerating and on idle. I tried to pin point the noise but it doesn't do it if your just revving the crap out of it, but I did here something tin sounding coming from the throttle body after you knock the rev's off? RE: Problems with my Xs already - Toms306 - 04-11-2013 It's an na petrol.....there isn't any power low down, that's what revs are for!
RE: Problems with my Xs already - Grant - 04-11-2013 Try and get a video up, its a bit hard to determine from your description
RE: Problems with my Xs already - underground375 - 05-11-2013 Like driving a 1.0L not good when you want to quickly turn into a corner. I will get a video later see if it can be heard. RE: Problems with my Xs already - underground375 - 06-11-2013 Well been looking along the engine and come across a exhaust leek coming from the manifold where it connects to the down pipe. Turns out the spring has rotted away leaving the bolt just sitting there. RE: Problems with my Xs already - Niall - 06-11-2013 You enjoy replacing that! :p RE: Problems with my Xs already - Grant - 06-11-2013 Piss easy on that type of manifold. It's the harmonised '6 ones that are a pig! RE: Problems with my Xs already - underground375 - 06-11-2013 I'm hoping the springs are the same on the Dt im breaking! That way it's just a simple swop over as I've got to get the decat pipe off anyway? RE: Problems with my Xs already - Chris1357 - 06-11-2013 1.8's are easy to get to the spring, 2.0's are a Bitch. Springs are the same Dan quick & easy job that. Chris. RE: Problems with my Xs already - underground375 - 06-11-2013 What I like to here Chris
