Cheap 306 TD - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Cheap 306 TD (/showthread.php?tid=18452) |
Cheap 306 TD - colin247 - 29-10-2013 Just seen this on eBay http://www.ebay.co.uk/itm/1998-PEUGEOT-306-D-TURBO-BLACK/271307621462?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D18221%26meid%3D2332491177501449388%26pid%3D100005%26prg%3D8339%26rk%3D2%26rkt%3D5%26sd%3D161136520387%26#ht_540wt_1171 RE: Cheap 306 TD - colin247 - 02-11-2013 (29-10-2013, 11:08 PM)colin247 Wrote: Just seen this on eBay The advert states this car has 130 bhp but it still seems to have a top mounted intercooler, do you think that is possible? Cheap 306 TD - Sambarker - 02-11-2013 Definately not. If you exceed 100bhp with a top mount the engine will explode RE: Cheap 306 TD - underground375 - 02-11-2013 You can on a to mount, but hes was running 18psi I would of been lucky running that when I had my k14 turned up to 25! I don't like how he worded the advert and for ti to go for 230 the bidders didn't nether RE: Cheap 306 TD - padge - 02-11-2013 ofcourse you can get more than 130 from top mount. RE: Cheap 306 TD - Chris_90 - 03-11-2013 (02-11-2013, 11:35 PM)Sambarker Wrote: Definately not. If you exceed 100bhp with a top mount the engine will explode ![]() RE: Cheap 306 TD - londondan86 - 04-11-2013 (02-11-2013, 11:35 PM)Sambarker Wrote: Definately not. If you exceed 100bhp with a top mount the engine will explode ![]() This is a wind up! The tmic is an underrated cooler, a lot of people still run it with high boost and bhp outputs (and its free). There are a few on here running them with 180bhp+. Fmic's are usually added as they look much better and are more effective at cooling from a standing start and on a hot day where the engine can suffer from heatsoak. RE: Cheap 306 TD - sherman306 - 04-11-2013 Classic 'should fly through mot no problems' yeah and that's why you haven't done it RE: Cheap 306 TD - colin247 - 05-11-2013 Okay thanks for the info. |
