Using Engine Oil As Fuel? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Using Engine Oil As Fuel? (/showthread.php?tid=1840) |
Using Engine Oil As Fuel? - bigcheez2k3 - 27-02-2012 Is it possible to use the old oil from the sump as fuel? I'm guessing you could as it's still oil and should combust. Re: Using Engine Oil As Fuel? - Rippthrough - 27-02-2012 You'd want it through a lot of filtering first! Re: Using Engine Oil As Fuel? - declantg - 27-02-2012 It can be done, but will need to be filtered as said above ^^ Using Engine Oil As Fuel? - Jonny b - 27-02-2012 Ha ha I ran my 106 with lucas on whatever I got my hands on for a year!! Even had gearbox oil in at one point Re: Using Engine Oil As Fuel? - Connor - 27-02-2012 Police wont like it Re: Using Engine Oil As Fuel? - 4WayDiablo - 28-02-2012 Filter it and dilute it :-) Re: Using Engine Oil As Fuel? - Toms306 - 28-02-2012 Jonny b Wrote:Even had gearbox oil in at one point That must have smelt nice! hock:
Re: Using Engine Oil As Fuel? - Dan! - 28-02-2012 Filter it and it'l work fine. Re: Using Engine Oil As Fuel? - mooey65 - 28-02-2012 gearbox oil stinks worse when burnt. Re: Using Engine Oil As Fuel? - Dum-Dum - 28-02-2012 Throw in half a liter of engine oil with a tank, I found that my engine ran quieter with it mixed in. Technically illegal as no duty has been paid on it. Re: Using Engine Oil As Fuel? - darrenjlobb - 28-02-2012 Works perfect but sadly illegal on UK roads.... |
