fuel pressure regulator - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: fuel pressure regulator (/showthread.php?tid=18197) |
fuel pressure regulator - bighead02 - 20-10-2013 Hey all I really want a variable fuel pressure regulator as im getting in loads of air but not enough fuel so would you say this is the correct item for the job http://www.demon-tweeks.co.uk/performance/fuel-pressure-regulators/malpassi-adjustable-fuel-injection-pressure-regulator If not then could you recomend how I can get more fuel into the engine Cheers Craig. RE: fuel pressure regulator - Niall - 20-10-2013 What mods do you have!? RE: fuel pressure regulator - bighead02 - 20-10-2013 Ive got straight through from the down pipe back, air filter, cold air ram pipe, short shift, strut brace, lowerd 40mm lol sorry dude thought it myt be easier to list 99% of them let me no if u neee more info RE: fuel pressure regulator - Niall - 20-10-2013 You dont need a different fuel pressure regulator then. You will do more damage than good. If your having starvation issues, id check that your lambda is working properly, replace your fuel filter and run some fuel injector cleaner through it. RE: fuel pressure regulator - bighead02 - 20-10-2013 Fair comment will give That a go then cheers boss RE: fuel pressure regulator - Bernard8100 - 21-10-2013 (20-10-2013, 07:38 PM)Niall Wrote: You dont need a different fuel pressure regulator then. You will do more damage than good. I am totally agree with you. You are 100% good here that you do not need a different fuel pressure regulator then. Replace your fuel filter and run some fuel injector cleaner through it. RE: fuel pressure regulator - DazzaHDI - 22-10-2013 ^just copied and pasted Nialls post!! ![]() |
