Anyone know anything about petrols? - Printable Version
+--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18)
+--- Thread: Anyone know anything about petrols? (/showthread.php?tid=17811)
Anyone know anything about petrols? - Sambarker - 04-10-2013
Got an Ax.
1.0 tu engine 8v
Symptoms.
Will rev absolutely fine when stood, and happily bounce off the limiter
When driving and obviously under load, will cough and sputter after about 3000rpm and then when revs drop back down it almost cuts out.
Any ideas
RE: Anyone know anything about petrols? - Piggy - 04-10-2013
may be coil related.
wont show up if not under load.
or fuel...again, may rev happily without load...dont take much fuel to rev an engine to the limter when stationary
I've given carb a clean out, changed the fuel filter.
Only thing I can think is I've fitted a straight through exhaust and just cut all the wires going to the lambda in the old exhaust.
Could that cause it?
so you have no lambda sensor working???....that would do it if thats the case!
I'm a noob with petrols, first I've had for a while.
There's no hole for lambda in new exhaust, if I just wire sensor back up and leave it tied somewhere will it still work?
RE: Anyone know anything about petrols? - cully - 04-10-2013
no it measures the exhust gas and adjust the mixture
it needs to be in the exhust not the glovebox
Better stick it back in then!
RE: Anyone know anything about petrols? - darrenjlobb - 04-10-2013
Haha Sam epic fail!!!
RE: Anyone know anything about petrols? - Daniel306 - 04-10-2013
Its got a carb and lambda? Sure its not single point injection?
No it's injection.
At least my hydraulic handbrake is working well!
SPI.
needs the lambda.
cut the little bit out of old exhaust with the lambda nut in it and cut a gap in new exhaust and weld the nut in. Smile
(04-10-2013, 08:07 PM)Piggy Wrote: SPI.
needs the lambda.
Not a bad idea
My dads just suggested making the wires really long and clamp the sensor inside the back box. Would this work?
It's a straight through exhaust to a cherry bomb
It really needs to be in the down pipe
wont work in back box.
needs to be in collector or just after.
RE: Anyone know anything about petrols? - darrenjlobb - 05-10-2013
Put it where its meant to be sam, it will have a pretty drastic effect on the fueling!
Lol at the hydro e-brake Tongue
Anyone know anything about petrols? - Sambarker - 05-10-2013
Lambda back in place now (the correct place)
Still seems to be limiting itself to 4000rpm
Sat waiting for ecu to hopefully reset
Now and again it will be fine and rev to 7000
But then you let off throttle and it will be limited at 4000
Tried another coil pack, it's got brand new spark plugs, just had service, temp sensor just changed.
Starting to really f*ck me off now
RE: Anyone know anything about petrols? - John1.4 - 05-10-2013
unplug the battery and wait overnight, if that doesn't work then get yourself a tu5jp4 imo
Yeah I've left it unplugged
That's the long term plan
you on the AXOC at all?
(05-10-2013, 06:36 PM)John1.4 Wrote: you on the AXOC at all?
Don't post on it much been on about 6 years
lol i've not been on for a while, still lurk in and out now and then though
RE: Anyone know anything about petrols? - cwspellowe - 05-10-2013
7krpm? On a 1.0 TU?
Just fyi.. with no lambda connected it won't give you rev issues, it'll just overfuel like f*ck as the ECU defaults to a rich mixture to prevent detonation. Not sure what sensors are on a TU but with regards to XU's this can be caused mostly by lambda, TPS and coolant temp sensor.
My GTi was awesome when the TPS died, sounded like antilag with the Magnex fitted, a proper rapppappappappappaPOPpapapoPOPrapapapPOP POPrapraprapapap when doing like 30mph lmao
Anyone know anything about petrols? - Sambarker - 06-10-2013
(05-10-2013, 09:35 PM)cwspellowe Wrote: 7krpm? On a 1.0 TU?
According to my mahoosive fake Autogauge tacho
RE: Anyone know anything about petrols? - John1.4 - 06-10-2013
regularly had 7k on all my 954cc ax's think they went up to 7250 (same as mk1 vtr rev limit iirc)
the tu9 engines are properly basic - water temp for ecu, lambda, crank and tps, then water temp warning light and an oil pressure warning light, 954cc ax's didn't even have a rev counter
Been alright today after resetting ecu. However most of the exhaust fell off halfway through a stage and engine has developed a chronic wine.
Time to find a 1600 engine
RE: Anyone know anything about petrols? - HDIkyle - 06-10-2013
Hope you didn't lose your cherry!
RE: Anyone know anything about petrols? - THE_Liam - 07-10-2013
To be honest mate, TU engines are quite sensitive to back pressure. Did it do it with the original exhaust?
RE: Anyone know anything about petrols? - HDIkyle - 11-10-2013
Don't think he drove it much with standard exhaust
RE: Anyone know anything about petrols? - Rippthrough - 11-10-2013
Single point does quite a shitload of it's fine tuning from the lamda and the TPS, disconnecting it is a bit of a fail Big Grin
RE: Anyone know anything about petrols? - puglove - 14-10-2013
Facepalm lmao
