Check ive done my brakes right. - Printable Version
+--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19)
+--- Thread: Check ive done my brakes right. (/showthread.php?tid=17801)
Check ive done my brakes right. - Eeyore - 04-10-2013
Ok people. I swapped from my hdi brakes to gti6 ones and just want to check a few things...
Wheel off
crack off brake line
2 calliper bolts out
calliper and discs off
new discs on
new calliper on and brake line on.
tighten it all up.
Then bleed.
I bled the drivers side first and then the passenger side. Working my way closer to the pump which is correct?
Pedal has a bit more travel and is a bit spongey which is due to not having the bigger gti6 master cylinder?
and there is a 1mm gap between the brake lines and the calliper. Is that normal? It would do up and tighter and isnt leaking fluid so i presume its all good.
[Image: IMG_20131004_150738_zps4ab244b3.jpg]
Just wanted to double check as it was my first time with brakes etc.
RE: Check ive done my brakes right. - swampy - 04-10-2013
Spongey will be due to air in system still
Did you bleed the rears aswell??
RE: Check ive done my brakes right. - Piggy - 04-10-2013
yeah I would do the lot (bleeding)
it will also feel a bit soft/sprongy until the new pads/discs wear into each other.
did you clean the hub face off before fitting the new discs????
RE: Check ive done my brakes right. - Eeyore - 06-10-2013
just took the old discs off and new ones on. I didnt bleed the rears. I need to swap those callipers over soon as well. After driving over 500 miles since fitting them they definitely work as im still alive!
