306 won't start - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: Newbies (https://www.306oc.co.uk/forum/forumdisplay.php?fid=24) +--- Thread: 306 won't start (/showthread.php?tid=17799) |
306 won't start - Geoff - 04-10-2013 Hi there I am a newbie to the sight. I put a new clutch into my 306 1.9 diesal 1998 and I had the battery disconnected for a week, and now it won't start, I suspect the ECU but don't know what to do about it, has anyone any suggestions please? Geoff RE: 306 won't start - ginge191 - 04-10-2013 You hooked up some jump leads at all? And welcome along
RE: 306 won't start - Piggy - 04-10-2013 it hasnt got an ECU so it be hard to blame that. does it turn over? does it turn over quickly or sluggishly? are the gearbox earths to chassis all back correctly? did you wire up the glow plug relay ok? did you touch the wiring to the pump at all? (that should get you started) RE: 306 won't start - puglove - 04-10-2013 I out my money on gear box earths, but yeah as said it has no ecu
RE: 306 won't start - pugvivant - 04-10-2013 Hello and welcome, check all connections first and esp earth points RE: 306 won't start - Herby7 - 04-10-2013 Welcome |
