6' Calipers - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: For Sale (https://www.306oc.co.uk/forum/forumdisplay.php?fid=26) +--- Forum: Misc & Wanted (https://www.306oc.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: 6' Calipers (/showthread.php?tid=17759) |
6' Calipers - Dean - 02-10-2013 After a set of front 6' calipers, and possibly a M/C to go with it. Don't mind collecting, or can pay postage not fussed. RE: 6' Calipers - Scott - 02-10-2013 Ask Grant or Niall RE: 6' Calipers - Niall - 02-10-2013 Can do you 6 callipers, MC, pads and discs for £80 delivered. RE: 6' Calipers - Dean - 02-10-2013 Not trying to sound thick or anything, but the M/C was just thinking, does it matter if its 2 port / 4 port? ;p haha, but i'm interested in the stuff you've just said for £80. Any chance of keeping them till friday (payday) RE: 6' Calipers - Piggy - 02-10-2013 all 306 MCs are two port as far as I can recall RE: 6' Calipers - Dean - 02-10-2013 (02-10-2013, 10:30 PM)Piggy Wrote: all 306 MCs are two port as far as I can recall Thanks, just with owning 106's + a 206 they come in 2 port and 4 port. RE: 6' Calipers - Niall - 02-10-2013 The non ABS ones are 4 port. IIRC all GTi ones are 2 port. Yep i can keep it all till friday but would want a small deposit just in case RE: 6' Calipers - Dean - 02-10-2013 ill have to check the mc tomorrow, got me thinking how many ports its got.. lol RE: 6' Calipers - Niall - 02-10-2013 90% it will be 2. Most 306s had abs except the right pov spec ones. Drop me a PM when you know RE: 6' Calipers - Chris - 03-10-2013 Also got a set here, after £70 posted with a mc RE: 6' Calipers - Dean - 03-10-2013 (02-10-2013, 11:01 PM)Niall Wrote: 90% it will be 2. Most 306s had abs except the right pov spec ones. Drop me a PM when you knowIt's a 2 port M/C, but doesn't have an ABS pump... is that normal? RE: 6' Calipers - Niall - 03-10-2013 (03-10-2013, 08:43 PM)xdoddyx Wrote:Maybe they all had 2 port ones then!? Im sure i have seen 4 port ones before!(02-10-2013, 11:01 PM)Niall Wrote: 90% it will be 2. Most 306s had abs except the right pov spec ones. Drop me a PM when you knowIt's a 2 port M/C, but doesn't have an ABS pump... is that normal? Pads and discs with mine have done no more than 500 miles. RE: 6' Calipers - Piggy - 04-10-2013 Ive never seen a 4port one. but happy to be corrected. RE: 6' Calipers - Dean - 04-10-2013 (03-10-2013, 10:21 PM)Niall Wrote:Well i'll have them off you no problem, i'm at work at 12, but don't finish work till 9pm tonight.(03-10-2013, 08:43 PM)xdoddyx Wrote:Maybe they all had 2 port ones then!? Im sure i have seen 4 port ones before!(02-10-2013, 11:01 PM)Niall Wrote: 90% it will be 2. Most 306s had abs except the right pov spec ones. Drop me a PM when you knowIt's a 2 port M/C, but doesn't have an ABS pump... is that normal? So if you're on before i go to work then i can pay for them then, if not it will have to be tonight when i get home. |
