erratic idle - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: erratic idle (/showthread.php?tid=16869) |
erratic idle - jays306 - 28-08-2013 Hi, any ideas on what could cause my car to rev up &down between 750rpm & 1000rpm? Would i be right in thinking it could be the TPS or MAF on its way out. It doesn't happen all the time just every now & then. Thanks RE: erratic idle - Toms306 - 28-08-2013 My china estate did this, I never did find the fault which isn't much use to you lol. However I unplugged the MAF and it was still the same so I ruled that out..... RE: erratic idle - Matt - 29-08-2013 I'd give the tps a clean up and replace the maf
RE: erratic idle - Poodle - 29-08-2013 Giving the tps a clean is a good shout, make sure the connections and earth are in good condition too. |
