Gear box mount - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Gear box mount (/showthread.php?tid=16846) |
Gear box mount - Welshy_Pete - 27-08-2013 I've been looking at the mounts trying to work out which one it might be. I couldn't see much movement but after taking the battery tray out. I can see the gear box mount moving about when pushing the engine forwards and backwards so chances it will be this one? Is there much movement on the gear box mount by hand? 306 hdi RE: Gear box mount - Piggy - 27-08-2013 yeah the standard ones are quite fleixble. a new one helps. but I find it to be the sloppiest RE: Gear box mount - emmerce - 27-08-2013 It is good to replace other mounts as well - with new only one rest two will be damaged much faster. But the one on bottom is not easy changed without press and remounting axle - probably information are in guides RE: Gear box mount - Welshy_Pete - 27-08-2013 (27-08-2013, 09:00 PM)emmerce Wrote: It is good to replace other mounts as well - with new only one rest two will be damaged much faster. But the one on bottom is not easy changed without press and remounting axle - probably information are in guides Can this one be seen moving much the bottom one? I know somebody with a press no problem. RE: Gear box mount - ozonehostile - 27-08-2013 do you know if the mounts been undone? the gearbox mount has a metal sleeve inside that is pretty easy to lose if its undone RE: Gear box mount - Piggy - 27-08-2013 (27-08-2013, 09:35 PM)Welshy_Pete Wrote:(27-08-2013, 09:00 PM)emmerce Wrote: It is good to replace other mounts as well - with new only one rest two will be damaged much faster. But the one on bottom is not easy changed without press and remounting axle - probably information are in guides You can do it without removal of the casing and a press... if you buy a powerflex polybush which is well worth the money as even OEM bottom bushes die pretty quick and powerflex give lifetime warranty. RE: Gear box mount - ky jonzy - 28-08-2013 (27-08-2013, 11:57 PM)Piggy Wrote:(27-08-2013, 09:35 PM)Welshy_Pete Wrote:(27-08-2013, 09:00 PM)emmerce Wrote: It is good to replace other mounts as well - with new only one rest two will be damaged much faster. But the one on bottom is not easy changed without press and remounting axle - probably information are in guides ^^ This for the bottom mount! As its so easy in comparison also worth replacing the rest at same time, as mentioned they will commit suicide once one is replaced as they are the weakest links .... happened on mine after replacing the bottom i had to replace gearbox and now i have noticed a crack in the buffer and play in the mount so both will be replaced soon when i don't know but i will lol |
